BMW [10]
Buick [2]
Cadillac [13]
Chevrolet [27]
Chrysler [3]
Daewoo [1]
Dodge [32]
Ford [23]
GMC [8]
Great Wall [1]
Honda [1]
Hyundai [2]
Hummer [1]
Jeep [12]
Land Rover [4]
Lexus [2]
Lincoln [2]
Mazda [1]
Mercedes-Benz [1]
Mitsubishi [2]
Nissan [1]
Oldsmobile [1]
Pontiac [6]
Plymouth [1]
Skoda [1]
Subaru [3]
Suzuki [2]
Toyota [9]
Volkswagen [1]
Volvo [14]
УАЗ [4]
Среда, 22.01.2025, 09:43
Главная » Статьи » Обзоры автомобилей » Chevrolet
Chevrolet Small-Block engine
Introduction
Chevrolet's small-block V8 is a famous automobile engine. Soon after being introduced, it quickly gained popularity among stock car racers, becoming known as the "Mighty Mouse" motor, after the popular cartoon character of the time. This was often shortened to the "mouse motor"[1] for its compact dimensions and lighter weight, compared to other V8 engines of the time (Chevrolet would later introduce the larger big block engine, which gained the nickname "rat motor"). Production of the small-block began in 1955 with the 265 ci. engine. By 1957 it had grown to 283 cu in (4.6 L), and with the optional Rochester mechanical fuel injection, it became one of the first production engines ever to make one horsepower per cubic inch. This engine was used to power the Corvette, and the Bel Air at that time. It would later be extended to other vehicles as well, and replace the old style 265 V8s. The displacement changed over the years, eventually reaching 400 cu in (6.6 L), but none caught on like the 350 cu in (5.7 L) small-block. This engine is still in production today at General Motors Toluca, Mexico plant (primarily for the GM over-the-counter Goodwrench powerplants), but is no longer offered in current model year vehicles since the year 2004. Its production numbers were impressive, with more than 90,000,000 built. It has been produced in carbureted, mechanical fuel injection, and electronic fuel injection forms.
From 1955-74, the small-block engine was known as the "Turbo-Fire V8".
Although Buick, Cadillac, Oldsmobile, and Pontiac also designed V8 engines (see list of GM engines), it was Chevrolet's 350 cu in (5.7 L) small-block that became the GM corporate standard. Over the years, every American General Motors division except Saturn used the Chevrolet small-block, and its descendants (see GM LT engine and GM LS engine) continue as the company's mainstream V8 design today.
The small-block was on the Ward's 10 Best Engines of the 20th Century list.
Chevrolet tested the small-block twice with no water and no oil at wide-open throttle. The first time it lasted an hour and 15 minutes and the second time it lasted two hours.
Major Versions
Generation 1
The original design of the small block remained remarkably unchanged for its production run, which began in 1955 and ended, in passenger vehicles, in 2003. The engine is still being built today for many aftermarket applications, both to replace worn-out older engines and also by many builders as high-performance applications. There were, however many minor changes made to the engine over the years; these changes are listed below.
1955 - The first year of introduction in 265 cu in (4.3 L) only. As was fairly common for the time, no provision for an oil filter was included in the engine design.
1956 - Oil filtration was introduced, using a sock style filter in a canister.
1957 - The engine came with only front mounts, the side mount bosses were present but not drilled and tapped leaving its retrofitting problematic.
1962 - The block's cylinder wall casting was revised to allow four inch bores. Previously, only certain years of the 283 engine (1958-1962) could be bored safely to four inches.
1968 - The main journal diameter was increased to 2.45 in from 2.30 in and the connecting rod journal diameter was increased to 2.10 in from 2.00 in. This allowed the use of cast iron crankshafts as the previous parts were made of forged steel. The rod bolts were changed from 11/32 in. diameter to 3/8 inch. Additionally, the canister/sock style oil filter was now converted to use spin on filters. The oil fill location was moved from a tube on the front of the intake manifold to a cap on either side valve cover.
1986 - The rear main seal was changed from a 2-piece rubber design to a 1-piece rubber design that used a mounting appliance to hold it in place. This necessitated a change in the flywheel/flexplate bolt pattern as well.
1987 - The valve cover surfaces were changed such that cylinder head mounting lip was raised and the bolt location was moved from 4 bolts on the perimeter, to 4 bolts down the centerline of the valve cover (this design debuted on the Corvette in 1985, and Chevrolet 4.3 L the year before). Also changed were the mounting angles of the center 2 bolts on each side of the intake manifold (from 90 degrees to 73 degrees) and the lifter bosses were increased in height to accept roller lifters. The alloy heads for use in the Corvette still retain the non-angled bolts (center 2 bolts attaching to the intake). Also all carburetors were done away with and replaced by TBI (throttle-body injection) fuel injection that acts some what like a carburetor.
1996 - This was the last change for the Generation I engine, and continued through the end of the production run in 2003; all 1997-2003 Generation I engines were Vortec truck engines. The cylinder heads were redesigned using improved ports and combustion chambers similar to those in the Generation II LT1. Again, the intake manifold bolt pattern changed - four bolts per cylinder head are used instead of the traditional six. This change resulted in significant power increases.
SB2 and SB2.2
(Small Block/second generation) This engine was produced from 1996 to the present for racing applications only. The cylinder heads were redesigned and the lifter bores were offset. The valve sequence for each head was changed from the traditional E-I-I-E-E-I-I-E to a new I-E-I-E-E-I-E-I and because of this the camshaft was redesigned.
Generation II
LT1 from a 1993 Chevrolet Camaro Z28
See the GM LT engine page for more information on the Generation II small-block V8s, which differ mainly in their reverse-flow cooling system.
Generation III / IV
LS1 from a 1998 Chevrolet Camaro Z28
See the GM LS engine page for more information on the current family of General Motors small-block V8s.
Early Small Blocks
The first small block Chevrolet V-8 was a 265 cu in (4.3 L) engine that was developed in 1955 for the Corvette. The small block has remained popular due to its relatively compact size, light weight, and extensive aftermarket support.
265
The 265 cu in (4.3 L) V8 was the first Chevrolet small block. Designed by Ed Cole's group at Chevrolet, it filled the power gap in the 1955 Corvette lineup, producing an impressive 250 hp (186 kW). The little engine went from drawings to production in just 15 weeks. Besides its compact dimensions, the small-block was known for its novel green-sand foundry construction process.
Dimensions were oversquare - 3.75 in (95 mm) bore and 3 in (76 mm) stroke. The small-block's 4.4 in (111.8 mm) bore spacing would continue in use for decades. It was a pushrod cast-iron engine with hydraulic lifters and a 2-barrel or 4-barrel Rochester carburetor. The 1955 conventional passenger car version produced 162 hp (121 kW) with a 2-barrel carburetor, or could be upgraded at extra cost to a "Power Pack" version conservatively rated at 180 hp (134 kW) with a four-barrel Rochester and dual exhaust. The first production year of this engine had no provision for oil filtration built into the block; however, an add-on filter mounted on the thermostat housing was installed during production. Due to the lack of adequate oil filtration provisions, the '55 model year block is typically only desirable to period collectors.
The 1956 Corvette introduced three versions of this engine - 210 hp (157 kW), 225 hp (168 kW) with twin 4-barrel carbs, and 240 hp (179 kW) with a high-lift cam.
1955, 1956 Chevrolet Corvette
1955 Chevrolet, 165 hp (123 kW) (2-barrel) and 195 hp (145 kW) (4-barrel)
283
The 283 cu in (4.6 L) V8 was introduced in 1957. It was a version of the 265 cu in (4.3 L) with a larger bore at 3.87 in (98 mm). There were five different versions ranging from 185 hp (138 kW) to 283 hp (211 kW) depending on whether a single carb, twin carbs, or fuel injection was used. Power was up a bit each year for 1958, 1959, and 1960.
The 1957 engine featured Ramjet mechanical fuel injection, allowing the engine to produce 1 hp (1 kW) per cubic inch, an impressive feat at the time. For 1961, an amazing 315 hp (235 kW) was available from this unit.
1957-1962 Chevrolet Corvette
302
Chevrolet produced a special 302 cu in (4.9 L) engine for Trans Am racing from 1967-1969. It was the product of placing the 3-inch stroke crankshaft into a 4-inch bore block. Although the 283 also used a 3-inch stroke crankshaft, it was a low performance cast iron crankshaft. The crankshaft for the 302 was specially built of forged steel. This engine was used only in the first-generation Camaro Z28. Conservatively rated at 290 hp (216 kW), actual output was around 375 hp (280 kW). This block is one of 3 displacements that underwent a transformation for the 1968/1969 period when the main bearing size was increased from 2.30 in to 2.45 in.
307
A 307 cu in (5 L) version was produced from 1968 through 1973. Engine bore was 3.875 inches (98.4 mm) with a 3.25-inch (82.6 mm) stroke.
The 307 replaced the 283 in Chevrolet cars and produced 200 hp (149 kW) SAE gross at 4600 rpm and 300 lb·ft (407 N·m) of torque at 2400 rpm in the 1960s. The later emissions-modified versions produced just 115 hp (86 kW) SAE net, giving the engine one of the lowest power-per-displacement ratings of all time. Chevrolet never produced a high-performance version of this engine, though they did produce, for Outboard Marine Corporation, a high-performance marinized 307, rated at 235 hp (175 kW) and 245 hp (183 kW) SAE gross, depending on year, that shipped with the Corvette/Z-28's cast aluminum valve covers and Rochester QuadraJet carb. Chevy also built other versions of the OMC 307 rated at 210 hp (157 kW), 215 hp (160 kW) and 225 hp (168 kW) SAE gross.
One of the biggest myths about the 307 is that all the blocks were cast with a very low nickel content. However, some 307 blocks, such as casting number 3970020 with suffix VxxxxTHA (x's in place for date), had 010 and 020 stamped under the timing chain cover indicating high tin and nickel content.
327
The 327 cu in (5.4 L) V8, introduced in 1962, had a bore and stroke of 4 in (102 mm) by 3.25 in. Power ranged from 250 hp (186 kW) to 375 hp (280 kW) depending on the choice of carburetor or fuel injection, camshaft, cylinder heads, pistons and intake manifold. In 1962, the Duntov solid lifter cam versions produced 340 hp (254 kW), 344 lb·ft (466 N·m) with single Carter 4-brl, and 360 hp (268 kW), 352 lb·ft (477 N·m) with Rochester mechanical fuel injection. In 1964, horsepower increased to 365 hp (272 kW) for the now dubbed L76 version, and 375 hp (280 kW) for the fuel injected L84 respectively, making the L84 the most powerful naturally aspirated, single-cam, production small block V8 until the appearance of the 385 hp (287 kW), 385 lb·ft (522 N·m) Generation III LS6 in 2001. * L79, L84 1963-1965; Chevrolet Corvette. This block is one of three displacements that under went a major change in 1968/1969 when the main bearing size was increased from 2.30 to 2.4 inches (58.4–61.0 mm). In 1965 the SS malibu choice of the 327/350 hp know as the "L79", with a aluminum manifold, holley squarebore carb, chrome valve covers, a huge 8" balancer, huge 2.02" intake valves and could only be ordered with a 4 speed trans. It was also used in the Opel Admiral, Opel Diplomat and Opel Kapitan models.
400
A 400 cu in (6.6 L) small-block was introduced in 1970 and produced for 10 years. It had a 4.125-inch (104.8 mm) bore and a 3.75-inch (95.3 mm) stroke. Initial output was 265 hp (198 kW) and was only available equipped with a 2-barrel carburetor. In 1974 a 4-barrel version of the 400 was introduced,while the 2-barrel version stopped production in 1975. 1976 was the last year that the 400 was used in a Chevrolet Passenger car, available in both the A-Body and B-Body line. While popular with circle-track racers, the engine was prone to cooling troubles if cylinder heads without steam holes were used. They mostly put out 250 hp stock. Due to the way the block was designed, the 2 bolt main engines were stronger than the 4 bolt versions. The 509 2 bolt main block is the most desirable 400 block.
Later Small Blocks
This section documents the odd-size small blocks developed after the 350 appeared in 1969. Many of these basic blocks are variations of the 350 design.
262
The 262 was a 262 cu in (4.3 L) 90° pushrod V8 with an iron block and heads. Bore and stroke were 3.67 in (93 mm) by 3.10 in (78.7 mm). Power output for 1975 was 110 hp (82 kW) and 195 lb·ft (264 N·m). The 262 was underpowered and was replaced by the 305 the following year.
This was Chevrolet's second 4.3 L-displacement powerplant; two other Chevrolet engines displaced 4.3 L: the Vortec 4300 (a V6 based on the Chevrolet 350, with two cylinders removed), and a derivative of the LT1 known as the L99 (using the 305's 3.736-inch bore, 5.94-inch connecting rods, and a 3-inch crankshaft stroke).
This engine was used in the following cars:
1975-1976 Chevrolet Monza
1975 Chevrolet Nova
267
The 267 was introduced in 1979 for GM F-Body(Camaro), G-bodies (Chevrolet Monte Carlo, El Camino, and Malibu Classic) and also used on GM B-body cars (Impala and Caprice models). The 267 cu in (4.4 L) had the 350's crankshaft stroke of 3.48" and the smallest bore of any small-block, 3.500 in. The 3.500" bore was also used on the 200 cu in (3.3 L) V6, which was introduced a year earlier. (The 200 was a Chevrolet V6 engine based on the small block with the #3 and #6 cylinders removed).
It was available with a Rochester Dualjet 210 - effectively a Rochester Quadrajet with no rear barrels. After 1980, electronic feedback carburetion was used on the 267.
While similar in displacement to the other 4.3-4.4 L V8 engines produced by General Motors (including the Oldsmobile 260 and Pontiac 265, the small bore 267 shared no parts with the other engines and was phased out after the 1982 model year due to inability to conform to emission standards. Chevrolet vehicles eventually used the 305 cu in (5 L) as its base V8 engine.
305
The 305 variant of the small-block Chevrolet had a displacement of 305 cu in (5 L) with a 3.736-inch (95 mm) bore and 3.48-inch (88.4 mm) stroke. The 262 was considered underpowered for use in vehicles with a wheelbase greater than 110 inches, so GM engineers decided to increase the bore diameter from 3.671 to 3.736 inches (93.2–94.9 mm) and increase the stroke from 3.10 to 3.48 inches (78.7–88.4 mm) (from the 350). Some performance enthusiasts have noted a marked resistance to performance upgrades on the 305 because of its small bore, poor selection of aftermarket cylinder heads, and the relatively high availability of 350 cu in (5.7 L) engines.
Induction systems for the 305 included carburetors (both 2 and 4-barrel), throttle-body injection (TBI), tuned-port fuel injection (TPI), and sequential fuel injection (GM Vortec).
After 1996, its usage was limited to light trucks and SUVs as the Vortec 5000.
† California Emissions
The 305 was used in the following cars:
1977-1993 Chevrolet Caprice (includes Impala)
1977-1986 Pontiac Parisienne
1976-1979 Chevrolet Monza
1976-1979 Chevrolet Nova (also GM X-body clones after 1976)
1976-1992 Chevrolet Camaro
1976-1988 Chevrolet Malibu, Chevrolet El Camino, and Chevrolet Monte Carlo
1978-1992 Pontiac Firebird
1978-1980 Oldsmobile Cutlass (US Market only, Canadian market 1978-1987)
1991-1992 Oldsmobile Custom Cruiser
1981-1987 Pontiac Grand Prix
1975-1979 Buick Skylark
1977-2003 Chevrolet/GMC Trucks, SUVs, Vans
1991-1992 Cadillac Brougham
1978-1987 Buick Regal
LG3
Years:1976-1980
Dualjet 2 bbl carb version with 8.5:1 compression.
LG4
Years: 1980-1987
The LG4 was the "low output" 305 cu in (5 L) (compared to the L69). It produced 150 hp (112 kW)-170 hp (127 kW) and 240 lb·ft (325 N·m)-250 lb·ft (339 N·m). The addition of a knock sensor for the engine management system in 1985 allowed an increase in compression and a more aggressive spark timing map in the ECM. As a result power increased for the 1985 models to 165 hp (123 kW) from the 150 hp (112 kW) rating in 1984.
L69
Years: 1983-1986
The L69 was the last true H.O. engine. The High Output 5 L (305 cu in) , featuring higher compression of 9.5:1 with heads of the to-be-discontinued LU5 Cross-Fire fuel injection engine, and utilizing camshaft and 4" catalytic converter of the 5.7 L (350 cu in) L83 which was used on the Corvette of 1982 and 1984. Complete with a 2.75 inch exhaust system, topped by a recalibrated 4-barrel carburetor, dual snorkel air cleaner assembly, aluminum intake manifold, aluminum flywheel, electric cooling fan, and furthermore a knock sensor including more aggressive spark timing, this engine produced 190 hp (142 kW) @ 4800 and 240 lb·ft (325 N·m) of torque @ 3200 rpm. In most cases, being mated to a 3.73 or 3:42 ratio limited slip rear axle and a T5 5-speed or 700R4 automatic, this engine provided its driver with a wide range of rpm to play in.
LE9
Years: 1981-1986
The LE9 5 L (305 cu in) was the truck/van version of the High Output 305. It also had flattop pistons for a 9.5:1 compression ratio, the "929" truck 350 camshaft for more torque, 14022601 casting heads featuring 1.84/1.50" valves and 58 cc chambers, a specially calibrated 4bbl Q-Jet, the hybrid centrifugal/vacuum advance distributor with ESC knock sensor setup, and lower restriction exhaust. The engine made 210 hp (157 kW) @ 4,600 and 250 lb·ft (339 N·m) @ 2,000 rpm.
L03
Years: 1987-95
The L03 was the "low output" 5 L (305 cu in) (compared to the 305 TPI LB9). It produced 170 hp (127 kW) and 255 lb·ft (346 N·m) of torque (190 hp (142 kW) at 4,400 rpm and 275 lb·ft (373 N·m) at 2,400 in 1993-1995 GM trucks). This engine used throttle-body fuel injection. The TBI uses a unique injector firing scheme: for every rotation of the engine, each injector fired twice.
LB9
Years: 1985-1992
Introduced in 1985, the LB9 was the first Chevrolet small block to have tuned-port fuel injection (TPI). It was introduced with 215 hp (160 kW) and 275 lb·ft (373 N·m) and varied between 190 hp (142 kW)-230 hp (172 kW) (with 275 lb·ft (373 N·m)-300 lb·ft (407 N·m) of torque) over the years offered. It was an option on all 1985-1992 Chevrolet Camaro & Pontiac Firebird models.
350
Not to be confused with Buick V8 engine, Oldsmobile V8 engine, or Pontiac V8 engine.
The first generation of Chevrolet small-blocks began with the 1955 Chevrolet 265 cu in (4.3 L) V8. But it was the 350 cu in (5.7 L) series that came to be emblematic of the Chevrolet small block V8 engine. The engine's physical dimensions (oversquare 4.00-inch bore and 3.48-inch stroke, 102 mm by 88 mm) are nearly identical to the 436 hp (325 kW) LS3 engine of today, but much has changed. It is by far the most widely used Chevrolet small-block; it has been installed in everything from station wagons to sports cars, in commercial vehicles, and even in boats and (in highly modified form) airplanes.
First usage of the 350 was in the 1967 Chevrolet Camaro and 1968 Nova producing 295 horsepower (gross); other Chevrolet vehicle lines followed suit in the year 1969.
The GM Goodwrench 350 crate engine comes in several variations. The lowest priced uses the pre-1986 four-bolt casting molds with two dipstick locations; pre-1980 on the driver's side and post-1980 on the passenger's side. This engine was produced in Mexico since 1981 as the Targetmaster 350, and now the GM Goodwrench 350.[citations needed]
ZQ3
Years: 1969, 1970, 1972-1975
The ZQ3 was the standard engine in the 1969-1970 Chevrolet Corvette. It was a 300 hp (224 kW) version of the 350 cu in (5.7 L) small-block, with 10.25:1 compression and hydraulic lifters. It used a Rochester "4MV" Quadra-Jet 4-barrel carburetor. This was the first block produced that featured the larger 2.45 inch main bearing versus the older 2.30 inch main bearing in 1968/1969.
The 1969 ZQ3 produced 200 hp (149 kW) and 300 lb·ft (407 N·m) with 8.5:1 compression, dropping another 10 hp (7 kW) in 1973. 1975 saw the ZQ3 at 165 hp (123 kW) and 255 lb·ft (346 N·m).
L46
Years: 1969, 1970
The L46 was an optional engine on the 1969-1970 Chevrolet Corvette. It was a 349 hp (260 kW), 380 lb·ft (515 N·m) version of the ZQ3 with higher 11:1 compression.
LT-1
LT-1 from a 1970 Chevrolet Camaro Z28
Years: 1970-1972
The LT-1 was the ultimate 350 cu in (5.7 L) V8, becoming available in 1970. It used solid lifters, 11:1 compression, a high-performance camshaft, and a Holley four-barrel carburetor on a special aluminum intake to produce 370 hp (276 kW) and 380 lb·ft (515 N·m). It was available on the Corvette and Camaro Z28. Power was down in 1971 to 330 hp (246 kW) and 360 lb·ft (488 N·m) with 9:1 compression, and again in 1972 (the last year of the LT-1, now rated using net, rather than gross, measurement) to 255 hp (190 kW) and 280 lb·ft (380 N·m).
There was also a later small-block engine called the "LT1".
L48
Years: 1967-1980
The L-48 is the original 350 cu in (5.7 L), available only in the Camaro or Chevy II/Nova in '67 & '68. In '69 it was used in almost everything; Camaros, Corvettes, Impalas, Chevelles & Novas. From '75-'80 it was available only in the Corvette. L-48's use a Hyd Cam, 4bbl Qjet, Cast pistons, 2 bolt main caps, "Pink" Rods, #0014 Blocks & #993 heads. Power output ranges from 300HP(gross) down to 175HP(net).
The L48 was the standard engine in the 1971 Chevrolet Corvette. It produced 270 hp (201 kW) and 360 lb·ft (488 N·m) with an 8.5:1 compression ratio.
The 1976-1979 L48 was the standard Corvette engine and produced 180 hp (134 kW) and 270 lb·ft (366 N·m). The 1980 L48 stood at 190 hp (142 kW) and 280 lb·ft (380 N·m) from 8.2:1 compression.
In 1972 the only way to get a L48 (4bbl V8) in a Chevy Nova was to get the Super Sport Package. This is indicated by the 5th digit in the VIN being a "K". 1972 was the only year you could verify the Super Sport package by the VIN.
In 1973 the "L-48" had cold air induction (throttle activated) and developed 190 hp (142 kW) (net). Beginning in 1974 the hp was reduced for several years until it reached a low of 165 hp (123 kW) (net) in 1975, before rising again.
L82
Years: 1973-1980
The 1973-1974 L82 was a "performance" version of the 350 producing 250 hp (186 kW) and 285 lb·ft (386 N·m) from 9:1 compression. It was down to 205 hp (153 kW) and 255 lb·ft (346 N·m) for 1975. It was the optional engine again in 1976-1977, producing 5 hp (4 kW) more. The 1978 L82 recovered somewhat, producing 220 hp (164 kW) and 260 lb·ft (353 N·m), and then 5 hp (4 kW) and 10 lb·ft (14 N·m) more for 1979. 1980 saw yet another 10 hp (7 kW) and 15 lb·ft (20 N·m).
L81
Years: 1981
The L81 was the only 5.7 L (350 cu in) Corvette engine for 1981. It produced 190 hp (142 kW) and 280 lb·ft (380 N·m) from 8.2:1 compression, exactly the same as the 1980 L48, but added computer control spark advance, replacing the vacuum advance.
L83
Years: 1982, 1984
The 1982 L83 was again the only Corvette engine (and only available with an automatic transmission) producing 200 hp (149 kW) and 285 lb·ft (386 N·m) from 9:1 compression. This was again the only engine on the new 1984 Vette, at 205 hp (153 kW) and 290 lb·ft (393 N·m). The L83 added Cross-Fire fuel injection (twin throttle-body fuel injection). Since GM did not assign a 1983 model year to production Corvettes, there was also no L83 for 1983.
L98
For the new Generation IV V8, see GM L98.
Years: 1985-1992
The new 1985 L98 added tuned-port fuel injection "TPI", which produced 230 hp (172 kW) and 330 lb·ft (447 N·m). It was standard on all 1985-1991 Corvettes (rated at 230 hp (172 kW)-250 hp (186 kW) and 330 lb·ft (447 N·m)-350 lb·ft (475 N·m)). Optional on 87-92 Chevrolet Camaro & Pontiac Firebird models (rated at 225 hp (168 kW)-245 hp (183 kW) and 330 lb·ft (447 N·m)-345 lb·ft (468 N·m)) 1987 versions had 10 hp (7 kW) and 15 lb·ft (20 N·m) more thanks to 9.5:1 compression. Compression was up again in 1991 to 10:1 but output stayed the same.
LM1
The LM1 is the base 5.7 L (350 cu in) with a 4-barrel carburetor (usually with a Rochester Quadrajet) in passenger cars until 1988. Throughout its lifespan, it received either a points, electronic, and/or computer-controlled spark system, to conventional and feedback carburetors.
LM1s were superseded with the LO5 powerplant after 1988.
L05
The L05 was introduced in 1987 for use in Chevrolet/GMC trucks in both the GMT400 (introduced in April 1987 as 1988 models) and the R/V series trucks such as the K5 Blazer, Suburban, and rounded-era pickups formerly classed as the C/K until 1996 which includes chassis cabs and 4-door crew cabs. Although usage was for trucks, vans, and 9C1-optioned Caprices, the L05 was also used with the following vehicles:
1992/1993 Buick Roadmaster sedan and station wagon
1991/1992 Cadillac Brougham (optional engine)
1993 Cadillac Fleetwood
1992/1993 Chevrolet Caprice Wagon (optional engine)
1993 Chevrolet Caprice LTZ
1992 Oldsmobile Custom Cruiser Wagon (optional engine)
L05 usage was replaced by the GM LT1 after 1993 in GM B-Bodies until production ceased in 1996.
In mid 1996 the L05 was equipped with Vortec heads used in the 1996 G30.
L31
The L31 replaced the LO5 in 1996 - known as the Vortec 5700. Known as the GEN 1+, this was the final incarnation of the 1955-vintage small block, ending production in 2005 with the last vehicle being a Kodiak/Topkick HD truck. Volvo Penta and Mercury Marine still produces the L31. The "MARINE" intake is a potential upgrade for L31 trucks.
Взято с http://en.wikipedia.org/wiki/Chevrolet_Small-Block_engine
Категория: Chevrolet | Добавил: t0nick (29.01.2009)
Просмотров: 4543 | Рейтинг: 0.0/0
Всего ответов: 12
