Вторник, 28.01.2025, 06:34
GM Trouble Code Info (Коды ошибок двигателей GM)
Accessing Trouble Codes
- Turn ignition switch to OFF position
- Locate Data Link Connector (DLC), see image below.
- Jumper the A&B terminals(a paper clip or a jumper wire work ok)
- Turn Ignition switch to ON position.
- Count the flashes on the "CHECK ENGINE"
or "SERVICE ENGINE" light.
- FLASH, pause, FLASH, FLASH = code 12
- NOTE: Some 94 & 95 models do not have the
B terminal. In which case a scanner is required.
- NOTE: Some 94 & 95 models that DO
have the A & B terminals still require a scanner.
- All vehicles after 96 are OBDII,and require a scanner to access
them.
12 Pin DLC
A - Ground
F - TCC
B - Test Terminal
G - Fuel Pump
C - Air Injection
H - Brake Sense Speed Input
E - Serial Data
M - Serial Data
Clearing Trouble Codes
Diagnostic trouble codes may be cleared by disconnecting the battery
ground cable for at least 20 seconds. Reconnect negative battery cable
and recheck codes to confirm the repair.
Diagnostic Codes
Select your Vehicle or look below for Generic codes.
Year
Eng
8th digit of the VIN Number |
82-83
2.5L
All |
82-83
3.0L
All |
86
1.8L
Multi Port Fuel Injection, VIN J |
86
1.8L
Throttle Body Injection, VIN 0 |
86
2.0L
Throttle Body Injection, VIN P |
86
2.5L
Throttle Body Injection, VIN 2 |
86
2.8L
Carb, VIN X |
86
3.8L
Fuel Injection, VIN B |
86-87
3.8L
Carb, VIN A |
86-87
4.1L
4.1L Fuel Injection, VIN 8 |
86-87
5.0L
5.0L Carburetor, VIN 9 |
86-88
2.5L
Throttle Body Injection, VIN U |
86-88
2.5L
Throttle Body Injection, VIN R |
86-88
2.8L
Multi Port Fuel Injection, VIN 9 |
86-88
3.0L
Multi Port Fuel Injection, VIN L |
86-88
3.8L
Fuel Injection, VIN 7 |
86-88
3.8L
Fuel Injection, VIN 3 |
86-88
5.0L
Carburetor, VIN H |
86-88
5.0L
Carburetor, VIN G |
86-88
5.7L
86-88
5.7L
Carburetor, VIN 6 |
86-89
2.8L
Multi Port Fuel Injection, VIN W |
86-89
2.8L
Multi Port Fuel Injection, VIN S |
86-89
5.0L
Fuel Injection, VIN F |
86-90
4.3L
Throttle Body Injection, VIN Z |
87-88
2.0L
Throttle Body Injection, VIN 1 |
87
2.8L
Throttle Body
Injection VIN R |
87-88
4.1L
Multi Port Fuel Injection, VIN 7 |
87-90
2.0L
Multi Port Fuel Injection, VIN M |
87-90
5.0L
Carb, VIN Y |
87-91
2.0L
Throttle Body Injection, VIN K |
88-89
2.3L
Multi Port Fuel Injection, VIN D |
88-89
3.1L
VIN T |
88-89
4.5L
VIN 5 |
88-90
3.8L
VIN C |
88-93
5.0L
Throttle Body Injection, VIN E |
89
2.0L
89
2.3L
Multi Port Fuel Injection, VIN A |
89
3.1L
Multi Port Fuel Injection, VIN V |
89
5.7L
VIN 8 |
89-90
5.7L
Throttle Body Injection, VIN 7 |
89-95
5.7L
VIN K |
89-91
2.5L
89-91
3.3L
Multi Port Fuel Injection, VIN N |
90
2.3L
90
2.3L
90
3.8L
VIN L |
90
4.5L
VIN 3 |
90
5.7L
VIN J |
90-91
2.2L
Throttle Body Injection, VIN G |
90-91
3.1L
90-91
5.0L
VIN F |
90-91
5.7L
VIN 8 |
91
2.3L
91
2.3L
91
3.8L
VIN C |
91
3.8L
VIN L |
91
4.9L
VIN B |
91
5.7L
91
5.7L
VIN J |
91-92
1.9L
Throttle Body Injection, VIN 9 |
91-92
1.9L
Single Port Fuel Injection, VIN 7 |
91-92
3.4L
Multi Port Fuel Injection, VIN X |
92
2.0L
Multi Port Fuel Injection, VIN H |
92
2.2L
VIN 4 |
92
2.3L
92
2.3L
92
2.3L
Multi Port Fuel Injection, VIN 3 |
92
2.5L
92
5.0L
VIN F |
92
5.7L
92
5.7L
VIN J |
92
5.7L
VIN 8 |
92-93
3.3L
92-93
3.8L
general & Supercharged |
92-93
4.3L
92-93
4.9L
VIN B |
92-93
5.7L
VIN P |
92-95
3.8L
VIN L |
93
2.0L
93
2.2L
VIN 4 |
93
2.3L
93
2.3L
93
2.3L
93
2.5L
VIN A |
93
3.1L
Fuel Injection, VIN T |
93
5.7L
93
5.7L
VIN J |
93-94
1.9L
93-95
1.9L
VIN 7 |
93-95
3.4L
VIN X |
93-95
3.4L
VIN S |
93-95
4.3L
VIN W |
93-95
4.6L
VIN Y |
93-95
4.6L
VIN 9 |
94
2.0L
94
2.2L
VIN 4 |
94
2.3L
94
2.3L
94
2.3L
94
3.1L
Multi Port Fuel Injection, VIN T |
94
5.7L
VIN P |
94-95
3.1L
VIN M |
94-95
4.3L
VIN Z |
94-95
4.9L
VIN B |
94-95
5.7L
VIN J |
94-95
6.5L
6.5 Diesel |
95
1.9L
Throttle Body Injection, VIN 8 |
95
2.2L
VIN 4 |
95
2.3L
95
5.7L
VIN P |
96
5.7L
VIN P OBDII |
96
5.7L
VIN 5 OBDII |
96
6.5L
6.5L Diesel |
97
6.5L
6.5L Diesel |
GM Generic Codes
Without Onboard Diagnostics (OBD-II) |
12 |
Diagnostic mode |
44 |
O2 sensor (lean exhaust) |
13 |
O2 sensor or circuit |
45 |
O2 sensor(exhaust rich) |
14 |
coolant sensor/high temp |
46 |
vehicle anti-theft system |
15 |
coolant temp/low temp |
47 |
air condition clutch and cruise circuit |
16 |
system voltage high (3.8L) DIS circuit |
51 |
PROM,MEM CAL or ECM problem (3.1L) |
17 |
- crank signal circuit
- ECM fault crank position sensor circuit (3.8L)
52 |
CALPK or ECM problem (3.1L) |
18 |
- ECM fault injector circuit (vin P-5.7L)
53 |
- system overvoltage
- EGR system (carb models)
- alternator out of range
19 |
- fuel pump circuit(shorted)
- crank position sensor(88-91)
54 |
- fuel pump circuit
- EGR fault (3.8L)
20 |
fuel pump circuit (open) |
55 |
O2 sensor or ECM |
21 |
TPS circuit |
56 |
vacuum sensor Quad drvier B (3.8L) |
22 |
TPS out of adjustment |
58 |
Trans code-TTS temp high |
21/22 |
grounded WOT circuit |
59 |
Trans code-TTS temp low |
23 |
- MAT circuit
- IAC sensor (95 models)
61 |
O2 sensor signal faulty |
24 |
vehicle speed sensor |
63 |
MAP sensor voltage high |
25 |
MAT circuit |
64 |
- MAP sensor voltage low
- RH side O2 sensor lean
26 |
- Quad driver circuit
- Throttle switch shorted
65 |
RH side O2 sensor rich |
27 |
throttle switch open |
66 |
- 3-2 Control solenoid circuit fault(4L60-E)
- A/C pressure sensor circuit out of range
28 |
Transmission range pressure switch |
67 |
TCC solenoid circuit (4L60-E) |
31 |
- park/neutral switch
- cam sensor circuit
- EGR circuit (88-90)
- MAP sensor (shorted)
68 |
O/D ratio error (4L80-E) |
32 |
- BARO sensor circuit(carb models)
- EGR circuit(injected models)
- MAP sensor(open)
69 |
- TCC stuck on (4L60-E &4L80-E)
- A/C head pressure switch circuit
33 |
- MAP sensor(low vacuum)
- MAF sensor
- MAP sensor(voltage high)
72 |
VSS circuit loss transmission output signal |
34 |
- MAP sensor(voltage low)
- MAF sensor
73 |
trans pressure control solenoid |
35 |
- IAC valve or circuit
- idle speed control circuit(shorted)
74 |
Trans input speed error (4L80-E) |
36 |
- MAF sensor
- DIS system(quad 4)
- transaxle shift control (3.8L)
75 |
system voltage low |
37 |
- MAT sensor temp high (3.8L)
- brake switch(4L60-E trans)
79 |
Transmission fluid temp high |
38 |
- brake input circuit
- MAT sensor temp low(84-86)
81 |
transmission 2-3 error |
39 |
TCC knock sensor shorted(4.3L)
82 |
transmission 1-2 error |
40 |
power steering pressure switch |
83 |
TCC solenoid circuit fault |
41 |
faulty ignition module cam sensor (3.8L) |
85 |
undefined gear ratio |
42 |
EST circuit |
86 |
low gear ratio error |
43 |
- ESC circuit
- knock sensor signal
87 |
high gear ratio error |
Материал взят здесь: http://www.troublecodes.nethttp://www.troublecodes.net/GM/
